Duplicolor Mirage paint
takeabao
Does anybody know if this is lacquer or enamel based??
I don't want to use lacquer since it chips easily...
It's a lacquer.
MIRAGE® Color Kit
Complete MIRAGE® Color Kit includes everything you need to create dazzling color shifting effects. Kit includes 1 can of Black Base Coat, 1 Can of Mid-Coat, and 1 can of Clear Top Coat. Kits available in 5 color shifting combinations: Purple/Green, Silver/Green, Gold/Magenta, Red/Blue and NEW Ice, a radiant silver color with brilliant rainbow highlights.
MIRAGE® Black Base Coat
Exclusively formulated to provide an even black lacquer base coat. It gives a smooth finish that's the essential first step to creating the desired color "shifting" effect.
MIRAGE® Mid-Coat Color
This exclusive, high-quality acrylic lacquer changes color depending on light, angle, and surface contour. It can be used on cars, trucks, bikes, helmets, skateboards, and other applications where dramatic color changes are desired.
MIRAGE® Top Coat Clear
Designed to provide protection and shine, this durable high-gloss clear lacquer is the perfect topcoat for MIRAGE® color shifting paint.
