DeaconFrost
- Sep 6, 2007
I'm having an odd issue with my WAP54G (latest firmware). I have it mounted in a conference room, and only recently I've noticed our SSID is showing up on all devices twice...once with security, and once without. If you click on the one shoing security and enter the passkey, you connect without issue. If you click on the one without security, you are told that you are unable to connect.
The problem I'm having is that I'm trying to set up a new MacBook Pro for my graphic designer, and in her wireless setup, the SSID only shows once, without the option for security. I am using WPA2-Personal. Is that not compatible with Macs? Is there something better I should be using? Why would I see duplicate SSIDs, and is there a setting/way to change this? They dupes show on all devices, including our iPhones, except for this one MacBook Pro. Very strange.
