Duplicate sound on another channel
RogueTadhg
I have a Z906, and I'd like to duplicate the Left channel on the Rear-Left. Making the 5.1 to a 2x2+1.1 (I'm not sure if this name exists).
Is there anything that can do this? I need to extend audio down a long room Extending speakers to the other wall isn't possible due to funds. It's far cheaper to go 50 feet instead of 100 ft.
Would I need to get an RCA splitter of some type? After thinking about it, software may not be the best answer to the problem at hand.
I don't know what you're looking for but two speaker drivers operating more than half the wavelength away from the other causes comb filtering (a very nasty disturbance in sound). You won't get a good result by playing the same sound, without delay and processing, in every corner.
