Duo Core VS Tom's Hardware
Status
Not open for further replies.
Serge84
http://www.tomshardware.com/2006/04/24/dual_core_intel_processors_for_low/page26.html
Sorry, Intel lied. Proof. Clams are bull now arn't they? Tom's hardware gets to the truth. It failed failed failed. This is shocking, no????????????????????????????
Core Duo is Intel's first step towards a new microarchitecture that will debut in Q3 2006. Its cornerstones are a wider instruction pipeline, larger cache, intelligent memory access, and a fusion of micro operations, macro operations and SSE enhancements (128 bit single cycle SSE). Intel claims to be able to outperform its competitor by 20% on a clock-to-clock basis, which initial benchmark results underscore. However, the performance numbers that can be found on the web are all based on Intel-assembled machines that could have been optimized: hybrid hard drive, tweaked memory options, and so on.
As we can see benches are not even close to 20% of a performance gane. More like 1% if none at all. Other benches show AMD does better overall.
You need to learn the differences between Yonah and Merom/Conroe before jumping to any conclusions. :rolleyes:
If you had bothered to read the article you linked, THG's conclusion is that a Turion 64 + K8NGM-V board (single core) used less power than a Core Duo + I975Xa-YDG board (dual core) in a comparison of low power systems. Things will change when 945GM chipset boards are available, as mentioned in the conclusion.
PLONK!
This "20%" you're talking about is Intel's claim about Conroe v K8. Sorry kid.
It was said by Toms hardware I just posted. :rolleyes:
Read the intire review and see what I copied from it Their exact words. :confused:
http://www.tomshardware.com/2006/04/24/dual_core_intel_processors_for_low/page6.html
Sorry kid but I didn't say it toms hardware does. And if ya looked at the benches they underscore in most FPS and CPU scores. And it was proven conroe was the same performance difference. Just wait until a real reviewer like toms hardware can prove intel wrong again. Intel puts up bogus clams even these Duo's can't back up. SOrry but I'd rather beleave a real reviewer then one by intel. :rolleyes:
Mod Edit ~ Papa-Ming : Closed for trolling in the Intel forum.
Status
