dumbfounded by DFI rep (HyperX 3500)
Glow
So I post on DFI forums and I ask will HyperX 3500 run on the DFI LANPARTY UT nF4 Ultra-D. It's not listed on their website that it can. I figured it be good to ask since the board seems picky about ram. So anwho he responds with "only way to really tell is to plug it in and see" Well, okay sure I would but I'm not going to spend $129 to figure this out. Is anyone running HyperX 3500 on this board or any of the newer boards here?
It's hard to expect them to know the compatibility of every single stick of ram. Is that ram BH5 based or what? I'm 100% sure it will run great in that board.
I don't expect them to know to a tee, but I would bet the engineers as a whole would have a better idea how Kingston ram will react to this mobo
i'm not 100% sure of anything in computervill these days.
but i haven't tried the DFI with the 3500 hyper x
there should be a bios that will work with it 618-1(GP) beta or 618-3 (tccd)beta
or one of the newer ones should be able to do the job with the new bioses there not pickey about ram . the bios the MB shipps with could be pickey though--
go to rebels haven and check on their page on the dfi-lanparty ultra D -- they did run a bunch of brands of ram on the DFI --can't recall if they ran hyper x --but i'll bet the have or at least ran the same chips as hyper x .
if you can't find any info on hyper x running the DFI -- try to find out what kind of chips are in the hyper x 3500 then use the bios recommended for that chip
