thyshallsmite
- Aug 17, 2005
forgetting to plug in the 4pin mobo power heh, was getting soo freaken pissed too that it wasn't powering on lol.
PigCorpse said:About that, probably not. My friend bent them all facing the outside (so he gets cut every time he plugs something in) and he hasn't had any problems. But if you get noticable interference, you can try doing that.
Edit: I'm not actually sure if it's electromagnetic interference, but they're for grounding (in general).
Double edit: Most motherboards now have metal rings around the holes where the screws go. If there are metal rings, the felt washers (should be red, if I understood what you were referring to) aren't necessary.
I always wondered what would happen if you removed the CPU while the computer was on. I would have guessed that the computer would just reset and not go past POST or freeze. You say that windows 3.11 was still running? Wow, I would have opened a program to see what would have happened!flynlr said:kinda a build boo boo./
back in 96 or 97 i had a P1 133 running on a board in my test bench . for some damm reason I decided to pull the CPU from the socket, which I did. only after doing so I noticed the power
was still on and win3.11 was still running. so I popped it back in moved the mouse around and all was well. I have never tried to repeat that little boo boo.![]()
PigCorpse said:Buying a Gigabyte motherboard, 'nuff said.
Broke off that little clip on the stock A64 heatsink that you're supposed to use a flathead screwdriver on to lock the heatsink in place.
ThatsAgood1jay said:Dumbest thing i ever did was forgot to turn on the power supply![]()
