Dumb Swapping MB question
Ok, so somehow, my ram shortcicuited and shorted out not just the ram, but the MB as well. Ordered a new one(both parts are fully fried, and I have NO idea how /shrug). However, I'm having an attack of absentmindedness when it comes to safe mode to backup everything I want off the HD before I format it.
With a new board, can I boot into safemode to copy all the files I want off before I format it for a fresh install? If not, is there a way, short of plugging the drives(boot and the 2nd drive I'm backing up on) into another computer that would allow me to back everything up properly?
Yeah just install windows without reformatting. Pop in the cd and run the install, select "install windows" or whatever, and make sure not to reformat. It will not kill your files.
uhh, is it the same mobo? if not, there is a good chance (assuming different chipset) you won't be able to boot into windows at all. If it IS the same, then yeah, no problems!
Different chipset(VIA vs. NForce), and I was under the impression that with XP pro you're best off doing a format/complete reinstall rather then just installing over an earlier install?
Well, you can do an install, back up your data, then reformat/reinstall if you don't want to put your drives in another system. Otherwise boot off of a knoppix disk or DOS disk and copy it that way, although if its NTFS it may not work.
yes, you should definately re-format, I was just saying for getting your stuff off, it might not work.
