IveBeenBad
- Jul 4, 2001
What are the advantages of say a Cisco 2501 over you standard SOHO router?
DVAmon said:Standard SOHO as in off-the-shelf NAT box or like a Cisco SOHO broadband router?
A cisco box is about as good as the person configuring it. If you know a lot, you can do lots of things. If you don't, you can learn. Cisco routers have an operating system on them called IOS, which is customizable based on need. Depending on your model router, port types and capabilities, and knowledge, you can configure quite a few things such as T1 access, frame relay, ISDN, links to other networks, an ip address other than 192.168.x.x, different routing protocols, where the metrics are customizable, or more than RIP at least, interVLAN routing, VLSM, etc. etc.
A basic D-Link or Linksys, Netgear...etc, or non-command-line-interface "routers" are basically preconfigured to perform NAT/PAT functions and port passthroughs as well as basic access listing via firewall configuration. Other than that, which is perfect for a home user as well as a network professional who doesn't feel like configuring a cisco box, it doesn't do much else.
Do you want something off the shelf that with minimal configuration you can begin browsing, or do you want something that with a bit of time invested, a lot of patience, and a hell of a lot of reading, may turn into a profession?
I'd go with the cisco, get at least (2) 2500 series, 3 if you can afford it, and maybe one or two 1900 series switches, and that'd be a pretty schweet CCNA lab to start.
