Jan 9, 2004 #1 C Comte Gawd Joined Jan 2, 2001 Messages 946 Do you have to hook up a reset button if you dont want to? I was sleeving my case wires, and the reset button wires got cut....Will that make a difference, or do I need to fix this problem? MB in my signature....
Jan 9, 2004 #2 W WackDaddy Limp Gawd Joined Sep 8, 2002 Messages 253 you just won't be able to use the reset button that's all.
Jan 9, 2004 #3 C Comte Gawd Joined Jan 2, 2001 Messages 946 Thats what I was thinking. Thanks for the reply....
