Basically what the title says. I never figured out what it is, but now i see theres a firewire to 1394 cord. Is 1394 firewire? Because i have one on my laptop, would like to be able to use it
IEEE1394 is the official name of Firewire. It's primary use is for video capture and external storage devices, but really can be used for multiple things, even a simple network. It's transfer speeds were extremely high compared to USB 1.0, but are less than that of USB 2.0. Basically it's just useful if you have a DV camcorder or external drive for the most part.
edit: also try this neat website I found http://www.google.com. I realize it's not very well known, but if you type IEEE1394 into it, the third link down is the definition. Google is one of those "tech secrets" I haven't really shared with anyone, now you're in the club too, OK? /edit
so if firewire is slower than usb2.0, do i need to enable usb2.0? I'm pretty sure my laptop (9300) has usb2.0, but doesnt seem to be going that fast when transfering info from laptop HD to external. Any clue?
Going on the assumption that you're running XP, you don't need to do anything to enable 2.0. If the external drive supports the 2.0 technology, you're going as fast as you're going to. If it doesn't, you would have to upgrade the drive to get the additional speed.
