Dumb question... how do I control case fan speeds?
Huggles
Hi there
I have a lian all aluminum giant ass tower. It comes with two fans on front and two exhaust fans. How do I set them up so that they spin faster? :) I can't find any control for them...
are you sure they're variable speed fans?? If not attaching a fan controller and upping the speed would prob just burn them out.
I don't know, they are so quiet and move so little air I figured I'd crank them up :p
You're not going to want to run the fans faster than their rated, as that would probably burn them out. I suggest just buying some new fans if you really need more airflow than those are giving.
Ok
Right now as is, I can barely feel any air moving in or out. I can put my hand over the intake and hand over the exhaust and I can just slightly feel air. I wanna be able to knock over a person standing behind my exhaust fan. :D
With the LL cases there is a switch located under the front panel that will adjust the fans. Remove the front panel and you whould have LMH on a small switch.
Concerning the rear fan - raplace it.
the lian li case fans are ok. i think you should just replace them with some vantec tornados
There aren't any fan controllers (to my knoweledge, at least..) that would let you overvolt your fans. Most, in fact tend to undervolt slightly.
