slowbiz
- Aug 24, 2004
I've got a normal flat screen monitor. My video card (geforce fx 5900xt) has got inputs for both regular monitors and the dvi input (I think that's what it's called). Anyways, the card came with an adaptor that switches the regular monitor connection to plug into the dvi port. Is there any advantage to using that plug and pluging into the high definition plug?? Or should I just leave it?
