Dumb 2005FPW Question
DistributedBen
I received my 2005FPW this week and had a question. This is my first LCD so bear with me.
Right now I have it connected via DVI to my main PC. With my previous monitor was was using a KVM to switch between two computers. Is it okay to hook the analog cable up an run it to the other computer and just swich between the two via the monitors controls? I just wanted to make sure this was okay for the monitor.
And BTW, this monitor is great! I big step up from my old 19in CRT. I do have a little light leakage, but it is only noticable when watching DVD's which I never to on the computer anyway.
Yeah it's fine if you want to do that, but I would highly recommend the DVi connection for whatever your main rig is. I'm a whore for trying to squeeze out as much quality I can.
Anyway, that's why the multiple inputs are there... so you use them. :)
yes, you need to squeeze as much juice as possible for your main rig. Its only ok, if you have a regular crt monitor.
