Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I would reccomend against it. Inverters are very sensitive, and can destroy themselves even under GOOD conditions. If it's a cheap CCFL set, go for it if you have the means to replace it, but I personally would steer away from this...
Using a set of 4inch cathodes on an inverter made for 12 inch cathodes is probably a bad idea, as, the output voltage required to run longer tubes is probably higher than what shorter tubes need...
I disagree. Performance PC's sells cathode sets and encourages you to add another 4 inch or 12 inch cathode to a single cathode/inverter combo. I'm planning on using a 12 inch and a 4 inch cathode on the same inverter soon, after I get them.
