kingdomwinds
- Aug 17, 2005
do you need to apply more arctic silver for dual core cpus? I ordered a 165 and plan to overclock it. Im wondering if this is necessary since the core is larger
KevinO said:
the heat will thin out the paste and the presure will squeeze it outwords to the correct thickness. how do i know this when i run an AXP machine? its cuz i have to keep replacing stupid dell GX270 motherboards due to bad capsUltraJounin said:I've heard (and actually did it myself) to put a tiny about (like you mentioned ALL4AMD) but then take a razor blade to spread it across the whole top then apply the HSF...
I assume this ISNT bad correct?
