MustangWorld
- Oct 4, 2004
So when i setup FAH on the machine, what machine ID's should i use? 1 & 3? I'm currently running 4 instances and want to cut it down to two so I can actually work on this machine too
OSUguy98 said:With a dual HT-enabled machine, you can run 4 instances... each would take "25%" of the whole.... But I would recommend against running all 4 with big packets... 1 or 2, yes... but not all 4...... Unless you have a few GBs of RAM.... F@H gets trumped by every other processor request, so it shouldn't be the cause of sluggishness (excluding the 4 instances on big packets).... RAM was likely what was slowly you down...
I would run 4 instances... 2 with big packets and 2 with regular units... You could even set the 2 regular unit instances up to run at 50% usage.... and that could allow you a little headroom with the processors (if you're concerned about using the PC regularly).... But getting rid of the big packets on a couple of the clients should solve your sluggishness....
Keep on Folding!!
Steel Chicken said:i run a dual Xeon w/HT at home. I run four instances, with each FAH setup having its own Processor ID. I am impressed with how quickly the HT threads get stuff done. The PC doesnot normally do much when im not home, so it gets alot of work done.
It has 2GB of RAM, which it never comes close to using.
MustangWorld said:How did you configure yours? big packets? advmethods? etc....
Steel Chicken said:sorry was short on the details. I configured the HT instances just like the regular ones, big packets ok, not timeless, etc. They seem to be working fine.
if you want more details, I can post a copy of the config file when I get home.
MustangWorld said:That would be cool. Either post it or PM, dont matter to me. Thanks a ton
