What do you guys recommend who have experience with a dual pump, dual watercooling setup...
I want to start fresh with a new case and setup....
I won't mind spending up to $400.00 for a dual watercooling setup DIY or kit....
Does having a dual pump require you to go through two rads, or is one of those heatercore from the bonnevilles sufficient?
How about two res's?
What kind of case do you recommend I get to fit all this, and how much power do I need from a PSU?
Will probably be powering an AMDFX, x800, all sata drives system....
