TOTALLY depends on the components you're cooling. Going from a single to a dual radiator, when cooling a Q6600 and an 8800GTX is the difference from "Zomg not stable + fire" to "moderately acceptable."
upgrading the rad will give you a larger heat capacity.
Unless you are using a Quad, or are using multiple waterblocks to cool various components, you might not see much of an improvement.
For a smaller heat overhead you could do better price/performance wise with upgrading the fan on your current single rad, or if using a large volumetric pusher perhaps a second fan? Examples would be a Delta EFB stacked on your current, (spins the opposite direction of regular fans so it can be stacked on another fan for an increase in airflow,) or another fan on the opposite side of the radiator.
All of this depends on your rig.
