Greetings,
I have decided on getting a UniFi AP, but I can't decide which one.
Currently I have a ESXi Server running Astaro (Sophos) for my router. I have an Astaro AP 10 and have used a MikroTik 751U in the past as well. I currently live in an apartment so I have a lot of WiFi congestion/noise and I have a lot of wireless devices. How does the UniFi do in these congested areas? I use inSSIDer and sometimes channel 1 has no one and then it had a bunch of congestion. Same thing for channel 11. Channel 6 always has a log of congestion.
My apartment is 1400 square feet and was built in 2008. The exterior walls are brick, but the interior walls are the typical uninsulated drywall.
I typically have music streaming to all of the SqueezeBox devices with about 1-2 dropouts per day.
I don't watch movies or push large files on the iPad or iPhones. But browsing pictures on my file server from the MacBook Pro over wireless is very painful.
I currently don't have a POE switch. I plan on getting something in the future, but the difference of having "real" POE in the PRO vs. Ubnt passive POE isn't a deal breaker.
My priorities is HD streaming on my Roku from online as well as local files (Plex). The SqueezeBox network also needs to not have dropouts. I don't plan on being in the apartment for more than 6 months in which I would want the AP to work well in a 3-4 bedroom house. I could of course get another UniFi AP to expand coverage if needed.
Thanks!!
My wireless devices:
802.11 b/g/n (2.4Ghz and 5Ghz)
iPhone 5
iPad 3
iPad 2?
iMac (99% Wired)
MacBook Pro (10% Wired)
802.11 b/g/n (2.4Ghz Only)
iPhone 4
iPad 1
iPod Touch 4G
Dell E6410 (Mostly wired)
Roku 2 XS
802.11 b/g (No N!)
SqueezeBox Touch
SqueezeBox Radio x2
SqueezeBox Receiver
SqueezeBox Controller
802.11b (No G or N!)
FitBit Aria Wireless Scale (This should be off except twice a day when it uploads data which should take just seconds)
- What do you recommend?
- The non-pro is just $70 on Amazon where the PRO is around $230 at various places. That is quite a difference. Is it worth it?
- A lot of my devices only support 802.11 b/g and one only supports 802.11b. Will this cause everything else to slow down?
Thanks!!
iPhone 5
iPad 3
iPad 2?
iMac (99% Wired)
iPhone 4
iPad 1
iPod Touch 4G
Roku 2 XS
802.11 b/g (No N!)
SqueezeBox Touch
SqueezeBox Radio x2
SqueezeBox Receiver
