Dual vid display with SLI?
stephpar
I'm new to the whole SLI thing and never did it with the voodoo2s either. If i'm running to video cards in SLI on a nice accomodating mobo(assume A8N if i can find one)...can i run two vga outputs...i.e my projector at the same time as my LCD monitor?
Probably an obvious question, but i don't seem to be able to find such an obvious answer.
Thx
Steph
you can run two vga devices off any modern videocard setup
SLI would theoretically give you up to 4 displayes
LOL, how ya figure? If you can get the drivers to turn SLI off and treat the 2 cards as two cards, then you could, but in SLI mode, the most you could have is 2 monitors, *assuming* the card has 2 ports on the back (which most do nowadays)
I have an A8N-SLI with two video cards.
In the NVidia driver menu, there is a section to disable SLI in the driver, even if it's set in the BIOS and the little controller card in between the video cards is set for dual card. I don't have multiple monitors, but I would assume turning off SLI would then let one run four monitors, assuming two ports per card, which like you pointed out is pretty common now. In fact, I'd pretty much assume any video card that is SLI capable currently can do such, not like there's THAT many with the little contacts on top to do that. ;)
So otherwise, yes one can turn off SLI. And even with SLI on, Windows sees it as two cards, but I do think the video ports on the secondary slot card's aren't active in SLI. I think. Maybe I'll get bored enough to plug in my monitor into them and see what happens. :)
hey thanks guys...i'd love to hear what actually works for output in this setup as the above posts point out, it's less clear that it would seem. Let's hear how it works for you Arvig....
Cheers
Steph
Cheers
Steph
Oh, for what it's worth, you know the little "chime' Windows makes when plugging in let's say a USB device into a USB port? I've noticed that any game using SLI at all will do a similar chime when it first comes up with any 3d graphics, without knowing I'm taking that to be the second video card powering up, like it's been in idle until needed. The second card does run a lot cooler most of the time, and doesn't really heat up much at all unless I check right after coming out of a game or video benchmark, so I'm getting the impression that the second video card just sits in idle until needed if in SLI mode, and the driver is also set for SLI. (Again, setting SLI in the BIOS and the controller card to 'dual card" really just seems to tell it to run two cards, and the two video slots as PCI-E 8x slots instead of running the primary slot as a PCI-E 16x, secondary as a PCI-E 1x. So...I'd think if SLI is inactive, the secondary card will be on, just like the first, thus then you could run four monitors at once, assuming each card has two ports. Can't remember which one, want to say latest issue of CPU, but I know I saw a print magazine reviewing SLI, and they claimed 4 monitors was possible)
