Thanks. I may have spares so I'll do some testing.
Stability will almost always be severely affected when using different processors. Hardcore multi-socket folk will often even swear by the fact that you need "matched pair" chips, (processors cast from the same die) in order to maximize stability. You might be able to use different processors, (probably not on those Supermicro boards) but it may not run as well as you'd hoped/at all.
