unless you really really love crysis, I don't think tri-sli is very important...at all, at the resolution.
No dual sli is not enough on that resolution.At least not in Crysis.
What 2 NVidia cards are equal to a 4870 X2? My ATI card can easily play at Very High with 8xAA.
Yes at 25 fps average thats not enough for me
What resolution and what cards are you considering?
..this is the key to all SLI - if you have a 25x16 monitor, assuming you don't CPU bottleneck, 3xSLI is probably worth it - as mentioned though, SLI and > gives diminishing returns...IMHO, stick with SLI and wait a little for TNBT from both ATI and Nv...GL![]()
1920x1080. For now.![]()
You'll want a 4Ghz+ i7 or a 4Ghz+ Quad to get all the benefits out of that third card. That being said, you can get perfect scaling out of games like Call of Duty 4. Unfortunantly, you don't really need more graphic power for that game. You'll still see good scaling numbers if you have the CPU to drive it. SLI scaling has come a long way, but you really do need fast CPU clocks to drive it.
Well it depends on the SLI, and PCI Express slots on the MOBO. Some motherboards have x16, x16, x4. There is no point to that and X16, x16 will be better.
