Dual screens`
brownkk
is it possible to run 2 screens, 1 using the video card and the 2nd using the onboard Mobo video output?
thank You
Depends. A lot of systems will disable the onboard graphics as soon as they see another card in the system. In that case no. If the board allows you to run both then yes you can.
What kind of video card do you have?
Most ones that came out the past few years have dual outputs.
yea.. this computer dosent have a video card with dual outputs so i was wondering if there was another way to do it...dont think i can with the copmuter
Why not just replace the video card or buy a cheap pci video card to use to drive a second monitor?
