Dual screen help!
Bigjmaster18
Im pretty much a noob at this but i have a Samsung 226bw and a Toshiba 32Rv530u and i want to connect both via dvi to my video card which is a 7950gt.
I have all the cables required but what should i do to make them both work at the same time?
You can right-click the desktop, you should see a option that says "Nvidia Display" and then lists the name of your monitor. Click on it. Otherwise you can open the Nvidia control panel nView display option. From here you can change the display mode to "clone", "horizontal span" or whatever it is you are trying to do.
You can also do it in Windows.
(right click on destop) Persnoalize -> Display settings.
Click on monitor 2 and check the box that says 'extend my desktop to this monitor".
