Dual rads question
halcyon
Ok here's a question for a possible system..
Eheim 1250, BIX (1 120mm), RBX on a mobile barton,MAZE4 on a 9700pro, 5 1/4 bay rez. All using 1/2 ID tubes. Now I have a swiftech 80mm rad sitting here and i have an 80mm fan on the back of my case.. would it be worthwhile to stick that in the loop? the fittings on it are 3/8" so i'd have to downsize my tube through that rad.. would that be way to restrictive on waterflow and negate any gains? Or would it be worth it? BTW the 80mm fan is just a vantec stealth but i figured more airflow to cool down the water couldnt hurt..
Thanks
I'd love to if my case could fit it effectively :D, or if there was a case you could modify that wasn't rediculously big you could do it with.
