I currently have a D5 variant pump pushing through 3 rads, cpu, 2 GPU's, and curious whether Its enough for 2 more GPU's (290) making a total of 4. I have 2 x 480mm rads (XSPC AX480), 1 x 280mm Black Ice GTS, and plan to add a 240mm Alphacool NexXxoS ST30 Rad. Is one D5 able to push through all of that and retain good temps? Or I absolutely need another D5 set in a serial pattern to raise the pressure of the flow?
If one pump is not enough, will this setup work properly by linking 2 pumps from 2 separate points into one another?
