Dual PSU
dp0001
building a rig and i already bought the psu- now i'm waiting for 8800.
there are rumors that this card will drain approx 350-450 watt, double that and you're in the 900's . my question is this: if i decide to go sli, assuming its even possible w/ new cards , would it be ok to buy a 1kw psu and only plug the cards on it. theoretically its sound right- 2 psu's: one for the cards and the other for the pc with all the hdd's
Rumors is the key word here... I doubt it will suck that much juice.
From the DailyTech Preview:
The marketing material included with the card claims NVIDIA requires at least a 450W power supply for a single GeForce 8800GTX, and 400W for the 8800GTS. Top tier vendors in Taiwan have already confirmed with DailyTech that GeForce 8800 cards in SLI mode will likely carry a power supply "recommendation" of 800W. NVIDIA's GeForce 7950GX2, currently the company's top performing video card, carries a recommendation of 400W to run the card in single-card mode.
These power requirements are for the whole system, not just the card, and include a safety margin. I'm guessing a 750 Watt PSU would be capable of carrying two GTXs in SLI, as long as it had enough connectors.
although the screenshots of the card dont show it, the manufacturers may opt to use and ext. PSU for just the card. IMO thats not the best idea but it may happen.
But...that was a good question! Is it possible to have 2 PSU's in one system? Not meaning one of those gpu psu's, but like a 2nd regular PSU?
-Ashley
Yes it is possible to setup two power supplies on one system. I had a server cube that needed two power supplies. I used an Enermax 480 for the mainboard and 10 case fans, and used an Antec TruPower 450 for the 9 hard drives (8 SCSI drives in a RAID-0 array, and 1 IDE for the OS), SCSI CDrom and Floppy.
ATX power supplies can be triggered "On" by grounding the "Power ON" wire (number 14 - green). I used a relay switching system, when the power button was pressed, it triggered the "main power supply", one of the main power supply's molex connectors fed the relay, which "closed" the power on circuit for the second powersupply, providing power to all the system drives.
They showed a picture on anandtech of a power supply for the new video cards that would fit in a 5 1/4 inch slot.
Talk about weird. I guess it would be a solution though.
I'm just hoping my Seasonic 500 watt will allow me to use a Geforce 8 or ATI equivalent. I have an AMD 3700+, 2 GB OCZ Platinum and don't want to build another system next year. Hopefully, it will be enough for UT2007. :cool:
I only have one hard drive and one DVD-RW so...
if the power requirements for the 8800's are as huge as they are rumourd to be, then a PSU, like the Athena 850, with it's 48 amp single 12 volt line, or the 850 watt Zippy PSU, would have a great chance at running 2 in SLI.
its hard for me to imagine 2 cards eating up that much power.
but if they did, running a PSU with a large single 12 volt line, on the videocards alone, would definatly do the trick to powering them.
if you want to see a pic of a working dual PSU cable, tell me, and I will post mine.
I use them even now, with my 850 watt PSU as a main, and a 550 watt as a videocard/everything else PSU.
so would you need to ground the connector to get the psu started or - once plugged in the video card it would give power automatically?// drive bays are interesting, i could run hdd's & opticals and save the rest for the cards
The "old" Coolermaster stacker case has room for two psu's. A special internal psu connector is included, so you could try to grab one those to be on the safe side.
Or you could just ground the green wire (PSU ON) with a paperclip connecting the Green and any black pins.
Yeah, but then the PSU is always on, so long as the switch on it is turned on...who wants to have to reach around to flip it on or off :p
-Ashley
That's true... I'm pretty sure there are adapters like the one posted above that you can buy online at the modding shops (frozencpu.com and performance-pcs.com)
The soon to be announced Antec P190 will come with dual PSU's in the case....along with a 200mm fan blowing cool air onto the video cards from the side panel.
My case can fit 2 regular size PSU's pretty easily with a little dremeling , but would have a hell of a time (in my specific build) fitting something like an enermax 1000w.
Just going for a TT 750w or silverstone for now and if need be will add a second later.
Thnx for the pic, i'm actually trying to get one off ebay for my ... "future needs" :D
The recommended FULL SYSTEM POWER for the 8800GTX is less than 500w.
The card it's self won't suck the quoted 450w. The card will probably suck about maybe 250w under the worst possible conditions, therefore making most current PSU's more than reasonable.
Anyone with a good 500w or above PSU should be FINE to run a GTX. Sli is another story :)
-Ashley
I had 2 PSus in my first TEC Watercooling project, enermax 465 and 365 the 365 for hte system and the 465 just for teh TEC / pump its easy to hardwire them together, just connect the green -> green on the main motherboard connector adn any black to any black from that same cable and when u power it up they both come together
BE WARNED THOUGH
if you ever do run 2 psus, and have one "just" for the vcards chances are you will fry your vcard, cuz if you power up a psu that is plugged into the card and not plugged into a powered on motherboard it will fry your card near the pci-e power connection
the card has to be seated in the mobo or else ~.~
well that was the case with AGP cards
(mainly 6800GT AGP)
