Dual psu holder thing
Bboy_Jon
i made the template for dual psus (might just skip the dual since i dont need it and it would be a hassle to have to turn it off seperatly and crap, plus i wont have a test psu), but SH*T i put it backwards, so i can have it at the bottom, with the fan pointing to the top of the case, or i can have the unit all the way at the top, with the fan pointing down, heres pics (btw which way would be better, all the way at the top or at the bottom)
Sorry for the size, o and its my first time being able to cut stuff witha dremel yaya!! and i was trying to smooth the edges with a wire brush attachment, but i used it on the template and it polished it, so i was like dang, and i had to finish the whole thing with it
so ya psu on top, fan pointing down only 3 screws holding it up
or
psu on bottom, fan pointing up, all 4 screws holding it
unless you've actually physically got 2 power supplies in there I'd put it on the bottom with the fan facing up, simply because then it has the extra support from the 4th screw. if you are using 2 power supplies then It wouldn't be too good either way because the fan will be jammed up against the other power supply in both cases. couldn't you mod it so that the power supply fan was facing up when it was in the top section?
Aside from that it looks really good, nice work.........but I'd hate to have to tidy the cables of 2 power supplies in 1 case :eek:
Ya thats why i think ill just use one psu
Btw, the fan blows air so itll be better facing up sweet!!! :D
does it suck air through the grill in the psu and blow it out into the case where the fan is? if it does that's kinda strange
chieftec full tower, on sale (was on sale) for 30 bucks at tiger direct, now there all out i think
