PogueMahon
- Nov 22, 2011
In the past I have set up a PC with 2 separate switches, one for each PSU. (via jumpstarting)
Just like the blue lines in this pic.
please note these are not the correct locations for the wire to be attached to the PSU.
I was wondering of I could go ahead and hook it up with just the red lines.
Basically just soldering on the 2 lead wires from the jump-started PSU to the same switch that the standard on/off wires from the mobo is connected to. So both will turn on the PSU together.
I am thinking this will not work, and should just drill another hold in the case and put a separate button for each PSU as I have done in the past. Any thoughts?
