Dual Processors
DakSLT2000
I am thinking about running dual processors but I don't know who makes a good dual processor board. Any suggestions?
i've decided to give you an award for the most vague post of the century... ;)
All in good fun... what platform are you going with? AMD Dual MP, opteron, xeon? A bit more info would be nice, if not necessary :p
I tak that award in stride, thank you very much. I want to be runnung 2 P4's, I'm either going to get another 2.4 so I would only have buy buy one. Or I would get 2 P4's that are over 3.0 Ghz. Its going to be on a Windows XP Pro platform. Basically everything I have listed below is going to stay the same. Except the ram, Mushkin is good but it is suck a pain in the but to get it to run right. Do ya need anything else??
P4's aren't SMP capable, you'll be needing to upgrade to Xeons if you want to stay with the Intel camp, which will quite honestly cost you a VERY pretty penny. You'll also have to upgrade your memory to ECC Registered memory, which will ALSO cost you quite a bit. The most cost effective SMP option as of right now (IMO) is the AMD MPx platform. you can but 2x Athlon XP chips and mod them to MP (this saves you a TON of dough, and is a very easy mod). Some people don't like the 'modded' processors and think that they are inferior, but really the only difference is one shorted/cut bridge.
You can run the MPx (unsupported, though) with non ECC memory, but i recommend picking up the ECC just for peace of mind. The new opterons are also something you might want to look at.
Well screw that idea, I guess I will just get a new processor for this computer and put this processor in my Compaq and replace the mother board in that thing. I have replaced everything else in the other computer so it should all work.
Asus PC-DL cost 200 right now. Stick a couple 2.4s (205 right now) in there and overclock them. Ecc is not needed on this board and it overclocks fairly well. The only thing I would recommend is anothr stick of ram to use that duel channel on it.
Its up to you your looking for a fairly good investment of 600 dollars.
i was pussy-footin around forever with the cheaper upgrades to do more. dualie was THE best decision ever! as an avid multi-tasker, i take for granted all that i can do now. unfortunately like other women with shoe-shopping, i impulse buy parts. tried the xp mod on 2000+ chips n didna work (though i'll plop em in the next pc i build for a friend). then the gig of corsair platinum i had bought for previous mobo wasn't compatible (another $300), so im runnin my dualies on an old stick of 256. i still get better performance than my guy's 'super pentium' system n i'm just about to get the right gig of ram from newegg. long story short, if you have multiple pc's, u can use the spares to upgrade those n build yer serverstation.
very happy!!!!!!!!
oh, n i ditched the wd's for 2X120 seagate barracudas
obviously the mem not the same either
n i have a gigabyte mobo, had to rma the asus
