The GTX 275 won't even pull 18A from the PCI-E connectors.
Power comes through the PCI-E slot and through the supplementary PCI-E power connectors. Specific voltages are delivered to the GPU and the RAM from the onboard power regulation circuitry.
Yes, obviously the PCI-E connectors use standard voltages. But that has nothing to do with using a second PSU.Good point, but the voltage provided to the PCI-e supplemental connectors are standard, I do believe. So make sure the motherboard is being powered entirely by one PSU, but if you like you can power the GPU on the second PSU. Someone correct me if I'm wrong.
Potential problem would be forgetting about the second PSU when moving from 120V to 220V country, and failing to change the voltage input switch on it. Solution: Only use auto-switching PSU for PSU #2.
that would be a problem with PSU #1 as well....unless you like fireworks.
Well, you really ought to be using a quality PSU with APFC so you don't have to deal with that problem altogether. A single good PSU is always a lot better than two crappy ones.
Yeah, but that one is visible so you'd ought to be able to remember that switch.
