SpeedDemon
- Aug 17, 2004
Does anyone know if there are any dual PCI-E x16 mobos out for athlon64's? Also, are athlon64's moving away from the Socket 754 tech to socket 939/940? And can 939's and 940's use the same motherboards? So are the nForce4 motherboards going to only be for socket 939/940 amd 64-bit cpu's? Are the nForce4 motherboards probably going to require DDR2 memory, or are they going to have the option of using it?
I'm trying to plan out my next upgrade because basically what I want to do is run a Athlon64 CPU on a nForce4 motherboard with either 2 GeForce 6600GT's if the performance is good or a next gen GeForce 6800GT with the option of adding a second for SLI? I'm kind of just wondering how much I'm going to have to upgrade though.
Thanks for the help!
