Dual Opteron for Gaming?
as much as a dual-opty system is great, I would say that you are better off with a dual-core system, especially if gaming is your main concern. If gaming is an afterthought for your dual-opty vmware kernel development platform, then the slight performance decrease shouldn't worry you anyway.
Maybe but not on that Supermicro board, get a Tyan Thunder K8WE instead!
You're joking right? You're not? Then shut up and learn something, kid.
The H8DCE's pretty much the board for it. Period. It's cheaper than Tyan, it's better quality than the Tyan, it's faster than the Tyan, it's more stable than the Tyan, the list goes on. Only an idiot or !!!!!! recommends the K8WE.
Versus X2's it's not even a contest with some games. The key is in the fact that the H8DCE gives four memory channels versus 2 out of an X2, and more HyperTransport links to increase total bus throughput. The increase from the second processor is very game dependent though. The 256's will rock X2's all day long if the game's multithreaded, like CoH/CoV. They'll hold their own easily with single-threaded games as well though.
This board looks the business .
I would like to see myself with something like this in the future, a dream come true.
Whoops, sorry I thought the Tyan didn't have cut off slots but it does :)
Maximum PC's dream machine from last year uses the Tyan, with dual dual core optys and 8 gigs of memory. The thing cost 12 grand in parts :)
yes the supermicro board is teh awsome!
you can game on it for sure... it is a little of an overkill just for gaming... but it can be just as fast as the best X2 dual core systems...
and with the potential for 4 cores... man... the beauty of AMD systems is they scale so well. you basically have a whole computer for every core you have.
ok, to sum it up... yes you can game... and with opteron and registered memory, with the good supermicro board... you will have a super stable PC...
just make sure you install windows xp64 to get full memory address capability... (16gb can be put into that board I think?) or is you need 32bit use windows server2003... at least you will get PAE mode with that. I don't think XP 32bit home or pro has PAE mode support (I think windows 2000 does... not sure why microsoft took it out for xp).
