Dual NIC's
Suprnova04
What would be the benefit of having two onboard NIC's as there on this this board?
Faster connection speeds? How would this work?
For using it as a server or some other part of a network. The first use I can think of is as a server. I would love to have a board with two onboard NICs for mine.
There are a couple of uses for two NICs.
One has already been pointed out. You can use one as an input an output to make the motherboard part of a server/gateway/router device. Many linux distros that do advanced routing need two NICs because of this purpose.
You can also use that computer as a hub like device. Some businesses run more than one network for security reasons and need some people to have access to both networks.
And finally, you can use it as a backup....
Suprnova04 said:
is it possible to "team" or "trunk" them to increase bandwidth?
no, youll need a multi WAN/load balancing router for that.
edit: or possibly some software to load balance it... but that would (probably) be costly, or in linux.
Well it is going to be hooked up to a router. Wouldn't it work to team them so that there was only one logical connection?
no. it just gives you two network connections. i do not know of a way to make one "logical" connection from them.
the router i was talking about has two WAN ports to accept two internet connections to give you double the bandwidth on the net, and they are costly.
You could bridge the connections in XP to double your data transfer inside your own network...as long as you have atleast one other PC with dual NICs, or use that system as a LAN gaming server...or somethinhg...
no?
no?
It is not that simple, a bit of googling will find you some of the answers. But really it is a driver level issue to do it right, and to REALLY do it right, you need a switch that knows how to do this as well. (managed switch, say $600 new at the 100mbit speeds)
There is an XP registry hack to split network connections between two nics on a random basis, but that really is not true load ballancing, and each NIC will still have it's own IP address, so if you are say, hosting a game if they are both on the same network, it will conflict with itself.
==>Lazn
You can team them together if the manufacturer of the NIC supports that as a driver option. Intel NICS for example all do this. The Intel Pro Set III doesn't even require the second NIC to be the same or be even the same brand.
In a team configuration you can have them set for fault tolerance, in case of failure, or you can have them distribute the bandwidth, it can be done on the PC, but really a switch that is manageable would be your best bet for maximum performance. In should be setup on both ends to work right.
And as stated before, dual NICS can cover more than one network. I have done this in a machine at work, it uses three NICS for three seperate networks.
