Red Squirrel
- Nov 29, 2009
I am looking into setting up ethernet bonding for my storage and VM server. My VM server has a dedicated IPMI port so that should not be an issue but my file server only has 2 ports with IPMI using one of them. Is there a way I can get bonding to work while also getting IPMI to work? I will also want the bonded network to be a vlan trunk, to add even more compexity. (not even sure if this can be done, I have to read up further).
Will I be able to still make IPMI work? If not, is there anything I can buy to make this work? Maybe some kind of USB based IPMI or something? I would just buy a dual nic card, but because it's a file server, all the slots are taken up by the sata cards to provide enough ports for the 24 bays. Unless someone can recommend me a non raid Linux compatible card that has more than 2 SAS ports. (each SAS port does 4 drives)
Worse case scenario I can stick to doing bonding only on the VM side, that's probably where it's more important anyway since the network has to be used simultaneously for storage and actual networking. (ex: file transfers over LAN from a VM) Though bonding on the file server side would be nice too.
