DUAL MONITORS: taskbar continuation?
Tonybologna23
right now i have a second montor hosting my aim and media but since i have so many windows open my task bar gets clogged.
is there a way to continue the taskbar from one monitor onto the next?
I think ultramon is your only option using an ATI card. Nvidia's nView drivers have dabbled in this, but ATI needs ultramon.
ultramon is an awesome program, its the first thing i install after a format. I use it with my Nvidia cards Nview sucks.
Yes, Ultramon will let you have the task bar continue to the second display or even the third display, etc.
I'm pretty sure Hydravision will let you do it. So ATi does have its own solution.
