Dual monitors on mac mini?
If you go with a Dual or Triple Head, make sure that you get the digital version. Also, I believe that if you get a TripleHead2Go, you can use 2 monitors, and add a 3rd if you so desire later. However, I am not sure if the Mini can push this.
Official specs for the mac mini are 1920x1200 digital and 1920x1080 analog output, which isn't enough to to drive two displays, unless you're using 800x600 resolution for them.
dualhead2go or other matrox products will handle that. You can do it with the link above.
