Dual Monitors on an SLI setup...?
VanFanel89
Hi all,
I have two Pny 8800 GTS video cards in SLI setup on an MSI K9A Platinum motherboard (570 nvidia chipset). I am trying to get a twin monitor setup but can't figure out how to do it - am I understanding properly in assuming that it is not possible to set that up? Is there a workaround? Anyone?
Senor - re-read my question. I am asking about SLI mode. I know full well you can extend/clone monitors with twin output video cards.
You can't unless you use quadro cards. Sli with the standard geforce gpu as of right now is single monitor only.
Unless I'm mistaken, of course.
Stick in a PCI card if you need another monitor along with your SLI setup. Of course you won't be able to game on monitors connected to the PCI card.
Is there some quick change utility which will allow me to swap over to sli mode on demand rather then going into nvidia control panel all the time?
Actually you can. Look up SoftTH, the main card(s) do all the rendering and it uses a secondary PCI card as an extra display head to output to your other screen.
btw is there a utility that perhaps is not a quick on/off type of a think for SLI, but will allow to enable/disable SLI without rebooting?
