So I have a bit of a problem whenever I launch a full screen application and I'm a bit stumped.
Problem: Start fullscreen application. Primary monitor goes black, followed by secondary monitor. Both sit there black for up to 30 sec. Both monitors go back to desktop for a few seconds. Then primary monitor goes black again followed by secondary and again it sits there for up to 30 sec. Finally, application will launch. Once in application everything is fine. Upon exiting, this process is repeated in order to get back to desktop.
If I disconnect the secondary monitor, everything goes back to normal. This started when I updated to most recent amd drivers. I forget what I was on before, but I think I had previously updated around September of last year. It also didn't start right away. It didn't start until about a week after I installed the drivers. Even weirder, I've tried uninstalling the driver and running driver sweeper and then reinstalled the driver several times. Each time the problem will disappear for about a day, but then it comes right back. On the latest attempt, I only installed the display driver without CCC (I thought the newer version of CCC was causing it, I was on the older version before). Again, it worked fine for a day before the problem came back.
Anyway, if anyone knows how to fix this, or has any good idea as to what might be causing it, I'd be so grateful.
Specs:
Windows 7 64 bit
Intel i7-875K
HD 5870 (both connected by DVI)
Specs:
Windows 7 64 bit
Intel i7-875K
