Ok, I have hooked up both my monitors and also installed Ultramon to help things go more smoothly. Everything is working as well as it can be although here is where i need help/advice.
My primary monitor is a NEC MultiSync 1760VM and the secondary is a 15" CRT. Due to my desk size, the 15" CRT is closer to me which is ok, because it is not the one I am staring at most of the time. What the problem is though is that when I am looking at my primary monitor, the NEC 17" LCD, it appears as though my 15" CRT is "flickering" in my peripheral vision. However, when I look at the monitor, it is all good with no flicker.
I have tried a couple different refresh rates and it dont help. What could cause this and more importantly can it be fixed, or is this normal behavior?
