Pics are mandatory.Frank4d said:I built a system for work that has 15 PCI boards in one enclosure and 11 PCI/PCI-X boards in the other computer. They are connected by a pair of 2 Gbaud fiber optic cables which share memory between the two. One dual Xeon PC in the PCI/PCI-X enclosure controls both (they are one computer as far as software knows). Out of our price range though.
GlobalFear said:Pics are mandatory.
Thats the equivlant of sleeping with a pornstar around here.
board2death986 said:out of curiosity how much?
German Muscle said:
thermaltake is showcasing it and advertising it as a dual motherboard computer case. I frankly dont care tho cause two computers in one case is just not something id care to do. the case is decent but ill stick with my 600xs better chenmingAreEss said:Mozart is not designed or built for dual motherboards. And frankly, if you tried to put two high heat producing boards in there, you'd have nothing but problems.
Only one I know of these days is what KRI sells as the CK1200C.
http://www.servercase.com/miva/miva...Product_Code=CK1200C&Category_Code=Adv+Server
Frank4d said:Otherwise it is just two MOBOs in one case.
German Muscle said:thermaltake is showcasing it and advertising it as a dual motherboard computer case. I frankly dont care tho cause two computers in one case is just not something id care to do. the case is decent but ill stick with my 600xs better chenming
Edit: you ever get a chenming?
