Dual MCP350 Pump Setup Question
lostiam2
I'm upgrading my system and need some help on setting up my loop.
This is what I will be using:
2x MCP350 with Alphacool modified tops,
2x Swiftech MCR220 QP
DD-680i block on the NB
Alphacool NB-SLI block on the SB
QX6700 with Apogee GT
8800 GTX with a DD 8800 GTX Block
I'll be using 7/16" Masterkleer tubing
Will this work? All on one serial loop or would 2 seperate loops be better?
1st MCP350 -> 2nd MC350 -> 1st MCR220 Rad -> Apogeet GT -> DD-680i NB -> 2nd MCR220 Rad -> 8800 GTX -> NB-SLI SB -> back to 1st pump.
I have it all on one loop to make the tubing neater and I figured that the 2 pumps in series would be strong enough to power the whole loop or am I wrong? Thanks for any advice!
a single MCP655 would be enough to power all that...
hell, a single MCP350 would be enough.
So the flow won't be too restrictive with just one MCP350, even with 2 rads?
Flow really doesn't matter as much as most people would tell you.
I currently run my D5 pump on the "2" setting... And my temps are still identical to what they were on the "5".
For reference, I run a EK 8800 block, and 2 radiators (1 triple, 1 single), along with a TDX waterblock.
hmmm... you probably only need one of the modified MCP350's for your setup if you're not planning to have two 8800gtx's.
I'm only using one MCP350 w/ Petra's Top + 3/8" Tygon and I get around 42C (CPU), 45 (8800gtx + MCW60) and 50 (8800gtx + Koolance)
MCP350 has great head pressure, which makes it well suited for daisy-chaining. I don't think you'll have a problem using a single pump. If you find you're not getting the desired results, add the second one in later.
Thanks for all the advice from everyone. Should I keep everything on 1 loop or will my temperatures be any better on 2 loops, 1 for QX6700 and 1 for the 8800 GTX?
