Dual loop question?
AmericanX
Hey guys just have a quick dual loop question. Okay so im planing to run one loop to cool CPU and another to cool GPU. what im having a problem deciding is should i use two reservoirs and two pumps or one res and one pump. Meaning if i go the 1 pump and 1 res i will have to split the tubeing so that i can run tubing to the two rads. Than from there off to the CPU and the GPU, than back together again, completing the loop. Or should i just have two completely separate loops. Looking for pros and cons of both? Thanks
AmericanX
I suggest using the search feature, one serial loop, or two completely separate loops, in that order.
