Dual-Link DVI + Crossfire = no display :(
Esso
Hey guys,
So I've finally migrated out of the CRT world to my first LCD. I ordered a 'deal of the day' 2707WFP from Dell and then ended up shipping me a 3008WFP instead (w00t).
Anyway, I have connected my PC to a single-link DVI LCD before with no problems, however when I try to connect this "dual-link" DVI cable up to my system it does not show anything on the display.
I have a crossfire setup using a X1900 CF & X1900XT, am I supposed to just plug the dual-link DVI cable into the x-fire dongle (Y-connector that joins the two cards)? This is what I had tried with no luck; even on a cold boot (switched over to the DVI output of course).
Disconnecting this cable and using the VGA cable worked fine though, so I am not sure what the correct procedure is, sorry for not RTFM'ing - I just want to get this thing going ASAP.
Thanks in advance for your help!!
Pretty sure you can't. That is the first gen crossfire isn't it, similar or the same as what the X1800's had? No dual link over the crossfire y-dongle.
