Dual LCD setup....
GetFunk01
Is there any benifit to, or even if its possible, to run my main Gsync 144hz off the GTX1080 and my Secondary over HDMI on the i7 7700K.. When i run both on the gtx1080, i cant seem to get stable refresh rate on Desktop.. Its flutters between 144 and 120.. But if i unplug the HDMI secondary monitor from the 1080, the Refresh stays locked at 144hz on desktop.
Yep, I have a 770 with a GSYNC screen then 3 other monitors hooked up to my i7 4770k along with 4 others to another nvidia card.
You could have tested for yourself quicker than making the OP, much less waiting for a reply and then bumping after you received an answer.
Although I suspect it's motherboard related, as many motherboards disable the onboard chipset when a discrete card is installed.
