Dual inputs on an LCD
fatbob_158
I'm havinga hard time figuring out if when an LCD has two inputs, IE DVI and analog, does that mean you can plug two seperate sources into it? I know they make lots of monitors and LCDs that let you have multiple sources on a single screen, with a little button that lets you switch between sources, but i can't tell if a monitor that has DVI and analog supports this.
If anyone knows some 15 and 17 inch models that do it would be appreciated.
Any LCD with a DVI input will have a 15 pin Dsub input. Yes, the dual input allows you to drive the monitor from 2 seperate computers. For example, I have a development box and my regular box, along with 2 LCD's. With the press of a button on each monitor, I can switch which input the monitor uses and consequently switch between my 2 boxes.
Honestly though, you don't need to have an LCD with 2 inputs. Any KVM switch will allow you to switch 15 pin Dsub VGA connections, and these cost as little as $20.00.
Thomas
Thomas
Kvms are worthless. Every one I have ever used degraded the video at high resolutions. Started adding shadows to text and such. I actually bought my monitor because it has dual analog inputs. I tried a kvm on my old monitor but it just wasn't up to par.
:eek: so THAT'S what the button on the far left of my 1800fps do....ahhh very nifty indeed
