Dual HD4650's Good idea?
CF or Single Card
  • Total voters
    34
Xazax
I have a Mini PC, an Antec P180 white mini to be exact, and a DFI LP Jr. 790GX motherboard and just picked up from newegg.com Dual HIS HD4650 512mb DDR2, Good buy? Now before your rant about buying a HD4830/HD4850, they only costed 80 bucks for both. In CF will these card be able to play most games decent settings? I noticed the cards dont have a CF Bridge so im wondering if they can be even Crossfired?
Cards
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161262
Would you kindly link us to the card you are referring to? Thanks in advance.
No, no, no.
You can get a single 4830 for $80 or less, easily.
The two 4650's are probably faster than a single 4830, but there's no way you should substitute a good single GPU with those two weak ones.
Well going buy reviews of HD4670's in CF they seem to either match or beat a single HD4850 and I guess with some Overclocking i could come close in Performance
seems like all the memory interfaces for the 4650 are 128-bit with ddr2 ram... I'd go for the the 4830 as well.
Much like the 9600GSO's with GDDR2, I think there still powerful if a bit bandwith lacking
But it's just best to go with a single card. The memory interface will kill it if you want to use it for anything with a decent res or AA.
I should mention though, im only using a 17" 1280x1024 monitor
then a single 4670 would work. next up a 4830 or a 4850 if like maxing out clear sky and such. there is no crossfire bridge on those cards anyways (that I could see)
Better than CF 4650's, I suppose...
I don't see a point of SLI/Crossfire a mid range card while you can get a mid high end card and you probably get the same performance. I say go get a 4850 and be done with it.
Considering u got 2 hd4670's for $80 and they perform as an hd4850 in xfire I'd say they'd be good for the money as you cant get an hd4850 for $80.
if you already bought them, link them up, you're fine. If not I agree go with the next tier up.
You mis-read the post, Im not saying im going to Crossfire HD4670's im crossfiring HD4650's What im saying is that Since most reviews point to Dual HD4670's performing well, and the HD4650's are only a grade down i believe with some overclocking i can close the performance gap somewhat. and Makes two HD4650's roughly equal a HD4850
Okay then, my initial point still stands.
You're completely going against the poll results.
Seriously, 90% of the vote should tell you something.
CAN you crossfire 4650? I thought that was the 4670 that had the crossfire capability . and I didn't see a crossfire bridge on that card you linked.
still for your 80 dollars I would get a 4830 and over clock it.
