Hi guys, last time i tried to order a server style quad gigabit nic for one of my servers i had bad luck (quad port). I always thought if it was intel branded (well it was a dell nic but manufactured by intel) i would be fine but unfortunately what i got would not work with server 2012.
Anyways now i'm looking for a descent dual port gigabit nic (PCIe 4x) that will work server 2012 R2 (if it works with server 2012 i'm sure it will be fine). I looking for a descent price one on ebay. I'm partial to intel but broadcom will be just fine. Can anyone recommend a model that they know works with server 2012 R2.
Other than can you offer any advice for the future to quickly decide if it will work with the latest windows server OS? I will be looking for another quad port nic soon. Sometimes its hard to tell exactly what intel branded card matches up to an oem branded card and then you have to try search if their are drivers. And if you cant find drivers thats not 100% because of course sometimes the OS will have the drivers.
