dual fan configuration
vividshock
So I have a Hyper 212 evo and I'm aiming to have a push-pull configuration. My question is how do the fans sync themselves with each other. The main CPU fan header is a 4 pin while right next to it is a 3 pin. Will these fans sync up with each other or will I have to browse my bios to configure some setting?
Use a splitter and run both from the same fan header. The header will handle two fans easy and then both will always be running at the same speed providing you use 2 of the same fans.
