Dual Ethernet
sdspark58
I'm looking to buy a new motherboard and was wondering what the dual Ethernet is for?
can you run 2 cables from you're router and have faster downloads?is it worth looking for a board with it i guess is what I'm asking.
it's POSSIBLE that if you have 2 internet connections (read, 2 modems and 2 incoming lines) you can bridge them under windows to double your effective bandwidth.
The real reason behind 2xGBlan is that it allows you to connect to your modem, but also allows you to connect another computer/laptop/router etc. to share the 2nd connection as you wish.
If you have 2 computers, this allows for 1000gb networking between the two (as long as the 2nd computer supports that protocol, if not it'll default back to 100 or 10mbps) for really REALLY fast data transfers, as well as a connection to your incoming line.
Some boards with 2 ethernet ports use the default chipset ethernet port, but also throw in another chip to run the 2nd port. Oftentimes these chips are BETTER than the onboard LAN connections, sometimes they're worse, but if you know what you're doing you can really use them effectively. I really, really wish I had dual ethernet, but for now I'm stuck with GBlan and IPoverFW for intra-computer connections.
